Extrusion Problems
Frontal_Impact
(@frontal_impact)
Extrusion Problems
Hi, I've got some specific extrusion problems. After first prints with this problem I've changed the nozzle and tighten extrusion gears. Calibration cube after this process is on the picture below. Then I decided to print quite big model, and I've seen, that this problem still exists :/ . Material: Prusa PLA, Printer: Prusa I3MK3S. New nozzle, new Bowden tube, what else could give such results?
Questa discussione è stata modificata 4 years fa da Frontal_Impact
Postato : 30/06/2022 10:18 pm
Zoltan
(@zoltan)
Utenti Moderator
Try please describe in this way
What do you mean by bowden tube?
Postato : 01/07/2022 7:27 pm
Frontal_Impact
(@frontal_impact)
RE: Extrusion Problems
By Bowden Tube I mean this PTFE tube that goes inside the radiator, above the heater block and nozzle.
Postato : 01/07/2022 9:03 pm
