Extrusion Issues
Postato : 06/04/2021 11:48 pm
RE: Extrusion Issues
Well, what setting did you adjust that made it fail? I would start with undoing that.
Postato : 07/04/2021 1:59 pm
Topic starter
answered:
@dan-rogers
The issue is that now when I load filament, the extrusion is bumpy and thin and when I do a first layer calibration there is under extrusion. The setting I adjusted doesn't affect those, it appears to be an issue with the extruder itself.
Postato : 07/04/2021 2:46 pm
do a couple of cold pulls and with the chamber empty, use the needle that came with your kit
Postato : 11/04/2021 10:19 pm
