Extruder wont to work wenn I print but work the rest of the time
MeuhDaCow
(@meuhdacow)
Hello everybody!
I am a Prusa user since 2019 and I am really happy with my I3MK3 udated to MK3S.
Today I have my first problem after km/miles of filaments printed...
My extruder make a "cloc cloc cloc" sound but ONLY wenn I print. I can load filament, unload it, I can purge nozzle with PETG and PLA without any problem. I can move extruder from the settings menu and the prusament go out properly. BUT... wenn I start a print I have on my bed a small amount of filament in all calibration points and the extruder is not able to make his job... He dont give anything during the print and sound like "cloc cloc cloc". I stop it and move extruder with the settings menu and all works... it is not clogged.
PTFE is clean, Nozzle is clean. I have done a cold push to test and all is clean...
I have reinstall the slicer and reflash the printer but nothing change...
You can see the "problem" here...
Really need you I am stuck...
Napsal : 27/08/2022 12:27 pm
RE: Extruder wont to work wenn I print but work the rest of the time
i suggest that your nozzle is too low. and the build plate is stopping the filament extruding
try readjusting your live Z. the negative number, is probably too big.
and try again.
Napsal : 27/08/2022 3:24 pm
MeuhDaCow
(@meuhdacow)
Oh thx i feel a bit stupide i was juste the live Z...
Really thx to you!!!
Napsal : 27/08/2022 3:42 pm
glad you are working again !
Joan
Napsal : 27/08/2022 5:44 pm
