Extruder thermistor resistance diffrence
Recently I had some issues with my extruder thermistor so I checked the resistance against the heat bed one and got 121.1 kΩ on the extruder and 118.9 kΩ on the heat bed I know there's not supposed to be a difference between the two so I just wanted to see if anyone knew if that's a big enough difference to cause an issue.
Opublikowany : 20/08/2020 7:28 pm
