Extruder struggling to extrude.. gear sometimes doesn't move and/or skips when printing
andrew.p25
(@andrew-p25)
My MK3 was working great but I accidentally had it print for about an hour with no filament loaded. 🙁
It now struggles to extrude filament... I tried heating up the nozzle and loading filament which led to a healthy stream of filament coming out but if I do any prints barely anything comes out and I can see the extruder gear sometimes not move and/or move slowly but then skip or stop moving.
Any idea what could be wrong and how to fix it?
Veröffentlicht : 20/09/2018 6:37 am
Re: Extruder struggling to extrude.. gear sometimes doesn't move and/or skips when printing
Although filament seems to be flowing well, I'd suggest doing a cold pull to ensure the hotend and nozzle are clear. Material build-up in the nozzle or hotend could account for the extruder problems you're seeing.
It's possible you've got other settings issues, but it sounds like everything worked before. Can you try re-printing gcode that worked previously?
Veröffentlicht : 20/09/2018 7:14 am
toaf
 toaf
(@toaf)
does the Z calibrate print?
rhjpires
(@rhjpires)
I have a similar problem happening with one particular filament, in my case the Janbex White PLA.
It gave rise to a problem described here in the forum.
https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f64/filament-stuck-to-print-head-brand-dependent-jam--t24631.html
Suggest the following:
  • Increase the temperature of nozzle to extrusion temperature of your filament
  • use the acupuncture needle to remove any clogs that may exist.
  • Use Setting > Move Axis > Extruder to extrude some material out (rotate knob towards higher values, i believe) and check if you see consistent filament movement and extrusion
  • If you don't see extrusion, open the idler door and inspect the pulleys, look for signs of dust that may indicate filament degradation.
    You may consider switching filaments to see if this is filament-dependent, or a more general problem.
    Also, consider doing a "cold pull" - don't forget to open the Idler door if you do so!
    Veröffentlicht : 20/09/2018 8:54 am
    rob.l6
    (@rob-l6)
    You have a partial blockage somewhere. Do the usual cold pull, needle up the nozzle etc. Minor blockages can have a tendency to hang around, just after you think you've cleared them they re-emerge, so be persistent.
    Veröffentlicht : 21/09/2018 4:24 am
    dustin.m2
    (@dustin-m2)
    How do you do a cold pull? Always says I need to preheat nozzle.
    Veröffentlicht : 25/09/2018 6:11 pm
    Neal
     Neal
    (@neal-3)
    Cold pulls is easy even for idjits like me. Here's how I do it.
    1) Open the door to the filament extruder gear. I usually turn off the filament sensor also.
    2) Set yourself up with some filament that requires a higher heat than what you last used. I use nylon from samples sent by the different filament clubs I have joined.
    3) Heat the nozzle up to the temp for the filament you have chosen to use.
    4) Hand feed it down the normal path it would follow if printing until you have some start coming out of the nozzle.
    5) Keep some slight downward pressure so it feeds slowly and turn off the heat to the nozzle.
    6) Once the temp drops to about 110 to 130 degrees (depending on what you are using for the pull) pull the filament back out.
    7) Look at the end you have pulled out and see how clean it is or is not. And note the shape of it also. Best to use a light colored filament.
    8) Clip off the used end as if you were going to normally load the filament.
    9) Repeat steps 3 to 8 until the filament comes out clean.
    Checking the shape of the filament end when you pull it out can help you see if your pfte tube is seated correctly.
    Hope that helps,
    Neal
    Veröffentlicht : 25/09/2018 6:28 pm
    CybrSage
    (@cybrsage)
    Hope that helps,
    Neal
    What shape is good and what is bad?
    Veröffentlicht : 25/09/2018 11:56 pm
    Neal
     Neal
    (@neal-3)
    Ideally it would be kinda flattish with a tiny little nipple on the end. Think of what the inside of your nozzle would look like and that is should act like a mold when you pull out the filament. That is the perfect shape. You don't want a bulb that is bigger in diameter than the filament.
    Understand that you pull the filament out melted in most cases so smooth and pointy is okay.
    Hope that helps,
    Neal
    Veröffentlicht : 26/09/2018 2:48 pm
    andrew.p25
    (@andrew-p25)
    Thanks for the reply!
    Yep everything worked previously for many long and short prints. I tried reprinting with the same gcode and I have the same fundamental issue (extruder seems to be weak... sporatic when extruding).
    Veröffentlicht : 12/10/2018 6:53 am
    andrew.p25
    (@andrew-p25)
    Thanks for the advice!
    I did a cold pull, acupuncture needle up the nozzle, and heating up the nozzle to ABS temperatures, same issues 🙁
    Veröffentlicht : 12/10/2018 6:55 am
    andrew.p25
    (@andrew-p25)
    Thanks for the reply, first layer calibration prints but not correctly due to the extruder sporadically slowing down and/or stopping. Attached is what my first layer calibrations have been looking like.
    Veröffentlicht : 12/10/2018 6:57 am
    andrew.p25
    (@andrew-p25)
    Thanks for all the suggestions!
    I've increased the temperature of the nozzle to ABS temps (previously only printed PLA). I"ve used the acupuncture needle. I've moved the axis and also loaded filament in an attempt to get any clog out. Filament comes out in what appears to be a healthy dose. Extruder still sometimes stops/slows sporadically during loading though.
    I've opened the idler door, pulleys are clean. I've only used Hatchbox white and the included Prusa silver. Switching to the Prusa silver yields the same problem 🙁
    Veröffentlicht : 12/10/2018 7:02 am
    anthony.r8
    (@anthony-r8)
    RE: Extruder struggling to extrude.. gear sometimes doesn't move and/or skips when printing
    Just started having this problem. My print actually quit out on me 50% of the way through at the 9:30 hour mark. I say quit out, but it was still moving around, just not extruding anything. It just stopped spitting out filament and was making unusual clicking noises. I haven't been able to feed anything through it, nor does it leave any filament on the plate during the first layer calibration. This is extremely frustrating as I just got it back from the shop and only printed 1 piece until it started to act up again. Different problem this time, but still.
    Some good suggestion here. I'll take a stab at using the acupuncture needle and heating the head up according to the notes above. I'll let everyone know how it works out.
    Diese r Beitrag wurde geändert Vor 6 years von anthony.r8
    Veröffentlicht : 12/11/2019 12:38 pm
    Posted by: @anthony-r8
    [...] Some good suggestion here. I'll take a stab at using the acupuncture needle and heating the head up according to the notes above. I'll let everyone know how it works out.
    Having experienced this problem a few times:
    • I'm hesitant to use the needle on a soft brass nozzle. After "rescuing" my original nozzle using the needle I realized I was having fine stringing problems. I tossed that nozzle and put on a new one and the problem went away. I suspect I damaged the all-important opening by twisting that needle around in there.
    • I've since adopted cold-pulls and have largely eliminated any sort of jams with most filaments. I run cleaning filament through whenever swapping nozzles or when changing between filament types, being sure to use a higher temperature than I print with (265C). I store each nozzle after cleaning it this way to ensure I don't forget and try to print PLA with a bit of PETG left inside the nozzle.
    • Be sure your extruder tension screw is not over- or under-tightened. Open the extruder cover and check the state of the filament, including shredding and filament dust (indicating over-tightened tension) or lack of Bondtech teeth marks on the filament (indicating under-tightened).
    • When in doubt, slow down. The Prusa default speeds for infill are very aggressive (Note: They do seem to have reduced them recently). You can slow down speeds individually, but I find adjusting the Filament settings->Advanced->Maximum volumetric speed setting for jam-prone filaments is the easiest fix. Prusa uses a default of 15mm^3/s for PLA, but my own casual testing shows that 11.5mm^3/s is more realistic. Reduce this value until you get reliable prints. Use preview mode after slicing to view resulting speeds.
    Veröffentlicht : 13/11/2019 1:49 pm
