extruder skipping
Zfrenchy
(@zfrenchy)
extruder skipping
I got a I3MK3S less than a year ago, printed only 3 spool of PLA and 1 spool of PET (all Prusament), I used only the default settings from prusaslicer (no mod of any settings)
Everything worked fine until two weeks ago where no filament came out at all.
I cleaned the nozzle (using the niddle shipped with the printer)
I replaced the Teflon tube
check all I can, but found nothing wrong.
Extruder still skipping when printing more than a hour.
Any ideas ?
Napsal : 21/09/2019 7:10 pm
RE: extruder skipping
I don't see that you've tried doing a cold pull to remove old filament from the nozzle.  Generally that's the best way to clean nozzle plugs.
https://help.prusa3d.com/article/lnbcnhg76k-cold-pull
Napsal : 22/09/2019 2:23 am
Zfrenchy
(@zfrenchy)
I think I found the problem, sound silly but no more extruder skipping.
I unmounted the extruder one more time to see what is going on, but found nothing weird.  When a remount all I DIDN'T TIE THE SCREWS TO HARD, since that everything work fine, even printed a parts for 3h without any skipping.
WEIRD !
Napsal : 30/09/2019 6:23 pm
Zfrenchy
(@zfrenchy)
I connfirmed, no more problem with extruder skipping steps.
the screws I didn't tie to much are the two screws on the top back.
Napsal : 23/10/2019 11:02 pm
