Extruder seperation
I recently switched my nozzle from my .25 to the original .40. When I started to print there were cobwebs and droplets of "brown" PLA regardless of the filament colour. I poked and prodded and cranked the heat up to (carefully) scrape off the extruder before loosening and tightening the nozzle to make sure it was close. The problem remains. I took the fan off the front and discovered that there is a gap the width of my scaple handle (15mm or so) between the heat sink and the block the nozzle screws into. I've looked at my assembly book and really can't see what the gap should be. Attached is a picture which hopefully adds to the explanation.
Opublikowany : 20/04/2020 2:48 am
