Extruder pulley does not turn during calibration or printing - turns OK only when loading and unloading filament
heink
(@heink)
Following  a filament runout event,  the extruder pulley only turns when inserting or withdrawing filament. I've replaced the nozzle, heatbreak, & PTFE tube.  The filament  extrudes nicely during the initial  Load Filament stage, and the pulley works when unloading the filament also.   During first layer calibration  The pulley is definitely not turning at all, and the PLA filament only seeps out of the nozzle under the heat.
Respondido : 15/12/2021 5:09 pm
BogdanH
(@bogdanh)
RE: Extruder pulley does not turn during calibration or printing - turns OK only when loading and unloading filament
Ok, pulley is not turning.. but does the extruder motor shaft rotate? If yes, then you need to check if pulley is properly fixed on motor shaft (one grub screw must be tightened on shaft flatness).
[Mini+] [MK3S+BEAR]
Respondido : 15/12/2021 5:30 pm
heink
(@heink)
the shaft and pulley are tight and will only turn at  load or unload filament
Respondido : 16/12/2021 2:35 pm
heink
(@heink)
Could a filament sensor malfunction cause this?
Respondido : 16/12/2021 2:36 pm
Is the extruder temperature above 170c. This is the low temperature extrusion limit
Regards Joan
Respondido : 16/12/2021 2:44 pm
Any clicking sound? Maybe a video may help diagnose it.
Respondido : 16/12/2021 2:59 pm
heink
(@heink)
Respondido : 16/12/2021 7:40 pm
