Extruder Motor Help
usmcsni
(@usmcsni)
Extruder Motor Help
My Extruder motor died even when disconnected from the printer it only rotates part way then locks up completely I need a replacement ASAP I use this printer for work and its costing me money while its down the prusa site is sold out any one know where to get a replacement OEM motor
Opublikowany : 05/07/2022 9:03 pm
jsw
 jsw
(@jsw)
RE: Extruder Motor Help
Lots of people who build clones and various RepRap machines get Moons motors from Amazon.
Opublikowany : 05/07/2022 9:10 pm
Netpackrat
(@netpackrat)
I am using this; works great:
https://www.partsbuilt.com/stepper-motor-x-y-e-for-prusa-i3-series-ldo/
Opublikowany : 06/07/2022 1:32 am
jsw polubić
usmcsni
(@usmcsni)
did you have to recalibrate your steps
Opublikowany : 06/07/2022 2:28 am
Netpackrat
(@netpackrat)
Posted by: @usmcsni
I'm not even sure what that entails. I used it in a scratch built Bear Upgraded version of the Prusa.  I had to modify the firmware for my raised Z, but beyond having to do that, when I hooked it all up it just worked.  As far as I can tell it's a direct replacement for the motor Prusa uses except it has a plug for the cable instead of having it hardwired.
Opublikowany : 06/07/2022 5:22 am
