Extruder gear access door screw is tightening
ga
 ga
(@ga)
The spring-loaded screw which holds the extruder gear access door shut on my i3 MK3S is self-tightening over the course of a 2-3 hour print.  This can cause it to be too tight and grind the filament.  Is anyone else seeing this problem?
Publié : 21/10/2021 5:47 pm
Simple answer is no.  How have you determined that its self tightening ? Filament grinding after a few hours is a normal sign of heat creep leading to the grinding but I have never seen anyone post that the screw has gotten tighter on its own.
I cant see how that is even physically possible given the design.
Publié : 21/10/2021 6:03 pm
ga
 ga
(@ga)
The head is more recessed
I am surprised it is tightening as well.  I can tell it is tightening because the head of the screw, which is normally about flush with the outside of the housing, is more recessed.  I can also see that the end of the screw is protruding more out the back side of the nut.
As a result, I've had to check it before starting a print and sometimes back it out.  On a longer print, which I haven't done since noticing this, I may have to back it out mid-print.
Publié : 21/10/2021 6:26 pm
Ringarn67
(@ringarn67)
Haven´t had the problem myself.
A possible fix, if the screw protrude from the nut, is changing the nut to nyloc nut
BUT, 🤔 my screw does not protrude from the nut at all, more like screwed in less than 2 turns in the nut
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Publié : 21/10/2021 7:00 pm
ga
 ga
(@ga)
My bolt is a duplicate from the spares
Hmmm.  My original bolt bound up in the nut; when I tried to unscrew it it rounded out the hex hole for the nut in the door.  I had to saw off the bolt to replace it.  So the current nut is free to rotate, but I would think any rotation would be *un*screwing, given the spring tension on the bolt.  I have printed a new door but haven't installed it.  I'm pretty sure the replacement bolt is the same length as the original.
Is your bolt head flush with the housing, more-or-less?  If not, how did you adjust the pressure to an appropriate amount?
Publié : 21/10/2021 7:27 pm
Ringarn67
(@ringarn67)
@ga
The bolt head is 2-3mm outside.
I autoload filament with screw as loose it could get without falling out, then tighten it until the filament start to extrude without clicking. Never touched it after that.
Publié : 21/10/2021 7:47 pm
If the nut is free to rotate that would explain the movement, your printer is not as it’s originally designed. If you already have a replacement door printed then I would fit it. It does not logically follow that the spring will cause it to loosen, it all depends in the order of pressure.
ga
 ga
(@ga)
Need to pick up a 3mm drill bit
Thanks.  I haven't put it on yet because I need to pick up a 3mm drill; the bolt and gear shaft holes are a bit under-sized due to filament squish, I presume.
Publié : 22/10/2021 2:56 am
Dan Rogers
(@dan-rogers)
Screw should stick out past the nut ...
Whomever's picture above with the screw barely seated in the nut - I'd advise a few more turns for PLA/PETG/ABS/ASA.   For TPU, your picture looks right.
Publié : 22/10/2021 9:05 am
