Extruder died
My extruder on my MK3s just stopped in mid print. Tried reboot but nothing. Where is the first place to examine please?
Postato : 26/03/2021 8:21 am
RE: Extruder died
First check all the electrical/electronic connections. Pull and reseat all the connectors, make sure that screw connections are firm.
If no difference you will have to do a little disassembly so that you can safely:
Try plugging the extruder stepper motor into a different socket - does it turn?
Try plugging a different stepper motor into the extruder socket - does it turn?
This *might* be a fix but should at least narrow down the problem.
Postato : 26/03/2021 10:08 am
RE: Extruder died
@diem
Good place to start. Also check the fuses to see if they tripped.
Postato : 26/03/2021 10:17 am
