Extruder calibration --> via extruder steps or extrusion multiplier in Slic3r?
Markster911
(@markster911)
Dear community,
I noticed some over-extrusion aka roughness of the top layer on my prints (have been only printing Prusa PLA or colorFabb PLA/PHA so far) ...
When I check my extruder calibration following these procedures on All3DP ( https://all3dp.com/2/extruder-calibration-6-easy-steps-2 ) or on Matt's Hub ( https://mattshub.com/2017/04/19/extruder-calibration ) I see a slight under-extrusion with the "stock" value of 280.0 steps ... approx. 5%. For clarification, I was just checking - not changing the value yet.
This is what Prusa says on the extrusion multiplier - https://help.prusa3d.com/article/d9j1xdg7vj-extrusion-multiplier-calibration - the pictures are interesting to compare ...
Now, when I print a 20mm calibration cube with the standard Prusa settings for PLA (extrusion multiplier is at 1.00 & "M221 S{if layer_height==0.05}100{else}95{endif} is active, not commented out) there is a slight over-extrusion visible at the top layer (some excess material at the corners) which goes away when I reduce the extrusion multiplier to 0.96 or more.
Standard Slic3r settings for Prusa PLA
Here the extrusion multiplier setting is extreme, at -10% ... are there microscopic gaps?
Is my understanding correct that in the way Slic3r is programmed it transforms an under-extrusion on hardware-side into an over-extrusion on the finished product? This would mean that I don't have to play with the extruder steps but just with the Slic3r settings, and probably per filament type ...
Cheers,
Mark
MK3 kit B7-R3 / custom FW v3.5.1 with 7x7 MBL
Slic3r PE v1.41.2
Postato : 05/02/2019 9:31 am
Markster911
(@markster911)
Re: Extruder calibration --> via extruder steps or extrusion multiplier in Slic3r?
Ok, I found this old thread https://shop.prusa3d.com/forum/others-archive--f66/updated-slic3r-pe-over-extrusion-and-cooling-solve-t12949.html which handles a similar topic but assumes that the Bondtech is calibrated well (mine is under-extruding) and Slic3r produces an over-extrusion ... interesting link to the M221 code function as a fix though (but I am already using M221 S95) ... so for me the question remains: do I calibrate the extruder steps or the extrusion multiplier or both or shall I play around with the M221 value?
I know, questions over questions 🙂
Cheers,
Mark
Slic3r PE v1.41.2
Postato : 07/02/2019 6:43 pm
