Extruded filament sticking to the nozzle rather than bed
98cbannister
(@98cbannister)
Hi, I have just changed my nozzle from a 0.4mm to a brand new 0.6mm to help me print with wood PLA. I am still experiencing a lot of issues and believe that the main cause is the filament getting stuck to the nozzle after extruding. I have tried changing the extrusion temperatures beginning wit 185ºc raising by 5ºc increments up to 220ºc. I have done the same with the bed temperature starting at 45ºc going up to 70ºc. Still no luck. I have also re adjusted the Z height on first layer calibration to no success. Has anyone else experienced this?
Publié : 16/06/2020 11:48 am
Flo4Print
(@flo4print)
RE: Extruded filament sticking to the nozzle rather than bed
Hi, just try to wash carefully your bed 1st, then carefully check your Z offset. Is it a genuine E3D nozzle ?
MK3S & Fusion 360
Publié : 16/06/2020 5:33 pm
