        Extract jammed filament and PTFE tube
Hello.
I need advice on the following situation: filament is stuck inside the extruder. I couldn't get the PTFE tube out.
I'm stuck at this stage.
What can I do?
                            Publié : 21/04/2025 3:31 pm
                    Topic starter
 answered:
                        RE: Extract jammed filament and PTFE tube
I also couldn't find a PTFE tube with an internal channel diameter of 1.85 mm... The closest similar one has a diameter of 1.9 mm (at least that's what they write in the product description).
Will it fit?
                            Publié : 21/04/2025 3:40 pm
