external spi flashw25x20cl is not responding
Louis
(@louis-3)
Well, just fired up my printer today (was working fine yesterday). Now I'm getting this message:
"External SPI flash W25X20CL is not responding. Language switch unavailable."
I don't care about the language chip. But the SD card is not working anymore. Yes I tried more than one and they all work on my computer. When I insert the SD card, it tries to read the content and show up blank and on the screen it otherwise says "No SD Card"
Tried reflashing 3.9.0, with the LCD connected and disconnected per the support page. Tried refreshing the MMU2 as well to 1.0.6.
Waiting on Prusa support now.
Napsal : 03/06/2020 6:56 pm
EDG Engineering
(@edg-engineering-2)
RE: external spi flashw25x20cl is not responding
What did support say?
I have the same thing right now.
Cheers
Ed
Napsal : 08/07/2020 4:53 pm
Louis
(@louis-3)
@ed-george
need to change the einsy board completely 🙁
Napsal : 08/07/2020 4:57 pm
EDG Engineering
Yes just saw that on Reddit as well someone with same thing. Just swapped over a screen from another printer keeps doing same thing.
Should still be in warranty so into support i guess!
Napsal : 08/07/2020 5:04 pm
@ed-george
maybe you have less bad luck than @louis-s4 and the einsyboard is not defective.
https://help.prusa3d.com/en/article/external-spi-flash-w25x20cl-not-responding-error_112019
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/upgrade-to-fw-3.3.1-on-mk3-caused-external-spi-flash-error/#post-99774
Napsal : 08/07/2020 6:18 pm
EDG Engineering
Thanks @karl-herbert.
I did go through all the flashing routine and various bits a while ago with support to no avail but as I only needed English I didn't worry about it. I usually print from octoprint so didn't notice until I started seeing another issue and they asked me to print from SD card... And ahh seems I can't do that either!
Napsal : 08/07/2020 6:28 pm
@ed-george
At long printing times I mostly work with the SD card and not octoprint. You may have to replace the board at some point, unless Prusa sends you an add-on board.
Napsal : 08/07/2020 6:58 pm
