Extending SD card reader on MK3 to reduce wear and tear.
PaulC
(@paulc-2)
Hi All, Has any one tried to use an SD card reader extension cable such as this "SD Card Extension Cable, LANMU SD to SD Extension Cable,SD Memory Card Adapter Convertor Extension Extender Cable" to minimize the wear of the on board reader on the main board of the Mk3?
I do get worried about the constant removing and putting back in of the card and that this constant use will cause it to not work much quicker?
Cheers
PaulC
Opublikowany : 06/02/2020 11:41 am
rmm200
(@rmm200)
RE: Extending SD card reader on MK3 to reduce wear and tear.
Mandatory plug for OctoPrint here. I have not used my SD card in the last couple of months. Take a look at it.
Opublikowany : 06/02/2020 6:00 pm
vintagepc
(@vintagepc)
I stuck a FlashAir card in my printer. Only time my SD card has come out since is when I was modifying the display and had to remove it from the plastic housing
Opublikowany : 06/02/2020 7:31 pm
