EXport and import configurations
Hello,
two week ago i bought a 0.2 nozzle to be used in my prusa mk3s the problem is that if a change the nottle size in prusa slider, it generate a new printer and all filaments and quality configuration paramters are empty, with this new printer, i i change the configuration to the 0.4 nozzle , the filament and quality configuration return to be selected.
Please do you know or exist any method to export import, configurations between printers into the prusa slicer?
I know tha in the file options there is a option to export and import but it is only between programs o to save the currently configuration but it is not import into the new printer.
thank yo very much in advance
RE: EXport and import configurations
I do not think this is possible. I think you have to add them to PrusaSlicer as an STL file or similar file and reslice the GCODE.
You might want to thoroughly read all the info available on Bob's site https://projects.ttlexceeded.com/3dprinting_prusaslicer.html as I foresee you will be doing some profile editing in your future.
