Excessive Y motor vibrations
MrNeedlemouse
(@mrneedlemouse)
I tried searching for this but all I found was issues related to the bed itself, I don't believe this is my case. I have excessive vibrations (stealth mode) on my Y motor at certain speeds. Most of the time it's really quiet, but this one is annoying and I think the vibrations actually transfers to my print quality.
Any suggestions on how to eliminate the vibrations? Please see this video where I just slightly press the Y motor with my finger during a print. Touching the bed or any other motor does not eliminate the sound, and I can really feel the vibration go away as I push the motor.
Ce sujet a été modifié il y a 5 years 3 fois par MrNeedlemouse
Publié : 31/05/2021 10:13 pm
MrNeedlemouse
(@mrneedlemouse)
RE: Excessive Y motor vibrations
The 4 screws holding the Y motor and motor mount could be tightened just slightly, about 10-15min each, this seem to have a big impact on the sound. For future reference...
Publié : 31/05/2021 10:27 pm
Dan Rogers
(@dan-rogers)
Here's a thought.  I eliminated my prominent Y motor noise by changing my Y motor mount.  The stock mount leaves the motor a paint coat thickness away from the back frame.  Certain movements cause a ton of resonance because the motor vibrates and that then bounces off the frame like a guitar string.  You can try a zip tie around the motor so it contacts the frame more firmly, but beware the zip tie hitting the bed at min Y.  Another solution is fold a piece of paper or plastic and slip it between the  Y motor and the back frame.  Or change the motor mount with a different one that doesn't squeeze the motor right against the frame.
Publié : 02/06/2021 5:16 am
