Error compiling firmware 3.13.0
3DStyle
(@3dstyle)
Hello,
I'm having difficulties to compile a custom firmware of the latest Prusa firmware - 3.13.0.
I tried to compile it using Arduino IDE 1.8.5, made sure to select Einsy board, made the changes in the plaftorm.txt file, and I get the following error:
avr-g++: error: unrecognized command line option '-std=gnu++17'
exit status 1
Error compiling for board PrusaResearch Einsy RAMBo.
Are there any other steps need to be done in order to compile this version?
Thanks!
Este debate ha sido modificado el hace 3 years 2 veces por 3DStyle
Respondido : 02/08/2023 1:36 pm
krajan
(@krajan)
Miembro
RE: Error compiling firmware 3.13.0
Hi
Have you solved it then? Can you share the solution if you remember, please?
Thanks
Respondido : 10/02/2025 4:06 pm
