ERR: Print Fan Error
Problem with my MK3s upgraded MK3. ERR: Print Fan Error. Consistent error during any/all prints. The error happens at the same line of code per each program. It even happens when I wrote a very short code to just run the print fan as a test. The fan is very clean and dust free. I've searched the site for answers but have found none. Please, what's the fix?
Seems that I can't print anything until my Mini gets here. Shipped today!
RE: ERR: Print Fan Error
So, to add more detail. Firmware setting is 3.8.1 All of these failures happen with PLA gcode. I have experimented with Prusa PLA, Generic PLA and my own PLA code and generic PETG
Problem solved. Corrupt firmware. After inspecting many potential issues, fan itself, electrical, code. etc. To no avail, I flashedback (sorry, wordplay) to firmware 3.8. Printer now operates as it should. I have successfully printed 4 different ~1 hour codes, programmed with Prusa Slicer and Cura. The thought of a corrupt firmware occurred to me when reading other posts about unreadable displays and similar posts. On another topic, my MINI will be delivered tomorrow!
I have two printer MK3 and MK3s and today start to fail the print with the same issue. With differents files, but stop in the same Z high.
I dont know if the error is for a profile update that crash the printing. The firmware in both printer is 3.8.0.
Do you change anything in the filament or printer profile, after reflashing the printer?
My printer firmware, at the time of fail, was 3.8.1. I do not know why or how it was corrupted. As I said I down graded the firmware to 3.8.0. Will re update when I can.
