End of filament not detected
Hello, my filament broke in the buffer, but the printer did not detect that there was no more filament and continued the job until I stopped it manually. The status of both the FINDA and the IR sensors was ok, both showing 0 in the support menu. Any clue what can be wrong here?
Thanks
Postato : 27/06/2019 4:12 pm
RE: End of filament not detected
Since the latest firmware upgrade and hardware 3 to 3S, I have the same problem. The new filament sensor is obviously working since the autoload function works, but the print does not stop when the filament runs out. I have sent several messages to support with no reply. What has happened to Prusa support???
Postato : 28/06/2019 2:34 pm
