end g code?
John
 John
(@john-8)
end g code?
My bed wasn't cooling down at the end of prints. I noticed the end g gode doesn't turn off bed heating. Can I insert M140 S0 code to do that? thanks john
Veröffentlicht : 24/06/2021 5:31 pm
RE: end g code?
Hi John
this is my end Gcode for a mk3S printer
G4 ; wait
M221 S100 ; reset flow
M900 K0 ; reset LA
{if print_settings_id=~/.*(DETAIL @MK3|QUALITY @MK3|@0.25 nozzle MK3).*/}M907 E538 ; reset extruder motor current{endif}
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M107 ; turn off fan
{if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+30, max_print_height)}{endif} ; Move print head up
G1 X0 Y200 F3000 ; home X axis
M84 ; disable motors
Veröffentlicht : 24/06/2021 7:29 pm
RE: end g code?
@JoanTabb -- Was it the M84 that the Mk3 uses to identify the end of a job? I recall if that was missing, it would hang at the end of a job.
Veröffentlicht : 24/06/2021 8:02 pm
