Dragon Hotend Mod keeps...clogging? I don't know exactly. Stops extruding anyway.
Hi everyone,
I have done a mod upgrade to my Prusa MK3S+ and I don't know what the issue is.
I got this one: https://www.amazon.de/gp/product/B086JQ929H/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Dragon Hotend High Flow. It printed for around 1h, and then simply couldn't push enough filament through.
If I start a new print, it won't work, I have to unload and then load the filament again.
This varies though. Sometimes it is after a few minutes, sometimes more.
- I've played with the tension screw
- I've added more thermal paste between the heating source and the heat block
- The PTFE tube fits correctly
- The Experimental feature for the motors is enabled to lower the temps a bit (the motor is a very hot)
- I've even increased the volumetric flow from 15mm3 to 20mm3
I am stumped, this is a 100euro 'drop in replacement' yet... I simply can't get it to work. Any advice is welcome!
Several. It comes out clean.
Do note that it was really hard to get the filament flowing. Heated the nozzle to 275, and I had to leave it there a bit to be able to push through, otherwise it wouldn't budge. After it started flowing, cooled it off just like in the manual/website and this came out, seems clean.
Nozzle
I was wondering if the issue could be the nozzle? I'm using the one that came with the Phaetus, and I think it is not a normal brass model, right?
Should I change the temps I'm using? Increase them a bit?
Can you post a photo of the cold pull?
Issue
Have your tried printing a temperature tower. I think this is either a filament issue or a temperature issue.
Issue
I have not, but I will. I doubt it is a filament issue, I'm using prusament that works perfectly usually.
Nozzle diameter
Could it be that it is a high flow hot end and I'm using a 0.4mm nozzle?
Temperature Tower
I cannot print it, the 0.4 nozzle gets clogged before finishing the first 225C part.
You sure you're printing PLA? I've seen stuff like this when I accidentally put a spool of PETG in instead of PLA.
pla
I'm printing this: https://shop.prusa3d.com/en/prusament/800-prusament-pla-vanilla-white-1kg.html
mmh
Reminds me that when I started to investigate the Dragon, I saw a boatload of reports of clogging with the high flow version, so I decided to go with the standard flow version instead, which has served me well.
Do you print inside an enclosure? I remember that as one of the scenarios that people reported make the high flow clog.
enclosure
Nope, it is open... 🙁
Clog
I am not having issues with clogging but I do not print that filament.
high flow?
so you're printing with a dragon high flow with a 0.4 nozzle? What temps are you using? What nozzle?
bump
Anyone got any ideas on how to fix the clogging? 🙁 I've tried upping the printing speeds, but to no avail.
clogs
Upping your print speed in a clog is only going to increase clicking. Imagine increasing the flow in a hose when you have it compressed, it is not going to increase flow. Have you tired to clear the clog? I do cold pulls, use acupuncture needles, and will use 1.5mm welding rods. It all depends on where the clog is.
clogs
I remove the clog, extrude some material to make sure it is unclogged, then print with the increased speeds.
