Downgrading MMU
gsezz
(@gsezz)
Utenti
Downgrading MMU
I have a MK3s with MMU Upgrade, and I'd like to downgrade it, because I don't use it and it causes issues almost every time I start a print.
Is it possible to just flash a Non-MMU Firmware to the printer, and put the Filament directly into the Extruder?
Questa discussione è stata modificata 3 years fa da gsezz
Postato : 12/07/2023 10:22 am
RE: Downgrading MMU
Unplug the mmu. And the printer reverts to basic.
Auto load may not work as normal. Because you have to push the filament into the bondtech gears
Postato : 12/07/2023 4:57 pm
1 persone hanno apprezzato
gsezz
(@gsezz)
Utenti
RE: Downgrading MMU
Thank you.
It turned out, some of the problems I had with the MMU might have been caused by the filament sensor. The printer often unloaded the filament at the beginning of the wipeline and was stuck in a unload - load loop. After removing the MMU it still did the same thing.
I reverted the the filamentsensor back to its pre-MMU state, and now it works perfectly. It wasn't as much work as I remembered from the upgrade. I didn't have to open the wire harness to pull the cable back, I could leave the extra length as slack at the printhead.
Postato : 12/07/2023 7:39 pm
Hello
(@hello)
RE: Downgrading MMU
Have you tried plugging a usb cable in the mmu and connect it to a phone charger while mmu powerd by printer search I found a massive designer flaw in the mmu
Postato : 12/07/2023 9:12 pm
gsezz
(@gsezz)
Utenti
RE: Downgrading MMU
No.
Postato : 13/07/2023 6:27 pm
