Does the thermal model in the MK3S firmware 3.13.2 work correctly with a copper heaterblock?
Stefan
(@stefan-3)
So i am a bit anxious ( or lazy ?? 😀 ) to load the latest firmware onto my MK3S.
The machine is running fine, but i would like primarily the added security from the thermal model.
My machine has a genuine E3D copper heater block upgrade.
I searched already, but found no answer...
Does the latest 3.13.2 firmware work without false alarms on a machine with the "E3D V6 Plated Copper HeaterBlock" ?
Postato : 21/12/2023 1:49 pm
RE: Does the thermal model in the MK3S firmware 3.13.2 work correctly with a copper heaterblock?
I don't know about that specific heater block but it works five with my Mk3S printers that all have Dragon hotends, which has copper heater blocks.
Postato : 22/12/2023 10:25 am
Stefan
(@stefan-3)
Thank you for your response.
It is mechanically identical to the MK3S stock heaterblock, but made of high temp copper alloy and therefor has a higher weight and heat capacity.
I will give the latest firmware a try 👍
Postato : 25/12/2023 10:34 am
