Does Prusa Link firmware support original i2c filament sensor?
Lockdown
(@lockdown)
I have just installed Prusa Link and I wish I did ages ago but I have an issue with the filament sensor after the mandatory firmware update.
I was running firmware 3.9.3 and it was perfect but after the firmware update it doesn't work any more.  When I downgrade back to 3.9.3 the filament sensor is perfect but anything above 3.10 that is required for Prusa Link to work breaks the sensor function.
I have the original i2c based sensor that Prusa no longer sell and I am wondering if they have dropped support for it?  I have a distant memory that you used to have to download the version of firmware that matched your sensor type but that doesn't seem to be the case any more.  Any ideas?
Opublikowany : 26/05/2024 8:03 am
