Does anyone have a clone Prusa i3 MK3S Bill of Materials?
Toprak1552
(@toprak1552)
I want to make a clone version but I can't find a complete bill of materials.
Respondido : 13/02/2021 6:27 pm
Miembro
RE: Does anyone have a clone Prusa i3 MK3S Bill of Materials?
Excluding the printed parts:
  1. 1*aluminum frame
  2. 1*front plate
  3. 1*rear plate
  4. 1*Y carriage+
  5. 3* U bolts
  6. 10* LM8UU bearings
  7. smooth rods kit-2*320mm+2*330mm+2*370mm
  8. 5. Aluminum Profiles kit- 2 * 205MM 3030 + 2 x*120MM 3030
  9. 4* Antivibration Feet
  10. 1* MK52 magnetic heated bed
  11. 1* steel sheet - PEI or textured
  12. 1*30cm sleeve cable for the heated bed
  13. motors kit-Nema 17 stepper motors - z axis with geared rod
  14. Einsy board
  15. 1*2004LCD
  16. IR filament sensor with cable(Set)
  17. PSU - power supply
  18. power panic cable and switch
  19. P.I.N.D.A V2 sensor
  20. 4010 fan
  21. 5015 fan
  22. e3D V6 heatsink extruder radiator with the block nozzle kit
  23. 50CM Textile Sleeve Cable Wire loom
  24. HT-NTC100K Thermistor Temperature Sensor
  25. 24V 50W Ceramic Cartridge Heater
  26. PTFE Tube
  27. drive gear extruder kit
  28. 2m gt2 belt
  29. 2 belt pulleys
  30. aluminum spacers for bed - 12
  31. Crap ton of screws and nuts.
Respondido : 15/02/2021 2:35 am
Toprak1552 me gusta
