Does anyone have a clone Prusa i3 MK3S Bill of Materials?
I want to make a clone version but I can't find a complete bill of materials.
Opublikowany : 13/02/2021 6:27 pm
RE: Does anyone have a clone Prusa i3 MK3S Bill of Materials?
Excluding the printed parts:
- 1*aluminum frame
- 1*front plate
- 1*rear plate
- 1*Y carriage+
- 3* U bolts
- 10* LM8UU bearings
- smooth rods kit-2*320mm+2*330mm+2*370mm
- 5. Aluminum Profiles kit- 2 * 205MM 3030 + 2 x*120MM 3030
- 4* Antivibration Feet
- 1* MK52 magnetic heated bed
- 1* steel sheet - PEI or textured
- 1*30cm sleeve cable for the heated bed
- motors kit-Nema 17 stepper motors - z axis with geared rod
- Einsy board
- 1*2004LCD
- IR filament sensor with cable(Set)
- PSU - power supply
- power panic cable and switch
- P.I.N.D.A V2 sensor
- 4010 fan
- 5015 fan
- e3D V6 heatsink extruder radiator with the block nozzle kit
- 50CM Textile Sleeve Cable Wire loom
- HT-NTC100K Thermistor Temperature Sensor
- 24V 50W Ceramic Cartridge Heater
- PTFE Tube
- drive gear extruder kit
- 2m gt2 belt
- 2 belt pulleys
- aluminum spacers for bed - 12
- Crap ton of screws and nuts.
Opublikowany : 15/02/2021 2:35 am
1 ludzie polubili
