do I need a new Einsy RAMBo?
Hi mk3+ has lost power half way through a print!
Checked fuses in plug (UK), psu, and the 3 in the Rambo. All are fine but still no power. Green led on psu is on. Display not working and can not connect with rpi via octoprint. Any ideas what to check next??
Thanks
Postato : 31/01/2022 3:19 pm
RE: do I need a new Einsy RAMBo?
Use a multimeter and check voltages. Juice stopped somewhere.
Postato : 01/02/2022 2:06 pm
All the green light on the power supply really means is it's getting power, you may have blown a fuse either in the PS or on the MB. I'd start by checking the power feed into the MB, probably the easiest place to start.
Regards
-Bob
Postato : 01/02/2022 2:59 pm
