Displayed heatbed temperature differs from reality
ZerwasMOD
(@zerwasmod)
Hi everyone,
I am having the situation that the displayed heatbed temperature in the printer display doesn't reflect reality of the temperature I measure, with an infrared thermometer, on the actual printing surface of the powder-coated spring steel sheet. So the preset 60° C for PLA of the printer actually are about 51° C I actually measure, and also PLA prints don't stick on the surface.
So I tested and tweak the heat bed setting to 85 °C to achieve real 60° C heatbed surface temperature, to achieve sticking prints.
Is there a way to set temperature offset in the printer, so the displayed temperatures are closer to reality as it currently is?
Publié : 22/10/2019 12:58 pm
Nikolai
(@nikolai)
RE: Displayed heatbed temperature differs from reality
Hi zerwas,
Everyone lives in his own reality 😉 .
Most likely your IR sensor readings are not accurate. Heat up the bed, remove the sheet and try to read it from different spots on the blank black bed. You should have a wide range of values because there are wire traces embeded.
I think you just need to clean your sheet properly and it will solve your adhesion issues.  Powder-coated spring steel sheets are known to require a perfect cleaning and perfect first layer.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Publié : 22/10/2019 6:31 pm
ZerwasMOD
(@zerwasmod)
Hi Nikolai,
thanks for your response. The problem isn't actually the adhesion in general when the I set the temperature to measured temperature rather then to the displayed temperature which is too low.
Publié : 22/10/2019 7:37 pm
Nikolai
(@nikolai)
Have you tried what I've recommended to do?
If you think your bed is not heating up to right temperature, then replace the thermistor. It's dangerous to try to compensate a sensor value which is essential for safety purpose.
Often linked posts:
Real Multi Material
Publié : 22/10/2019 10:06 pm
It's a measurement issue.  Wherever the thermistor is is probably what is showing on the display (within a few percent).  Since the thermistor is on the bottom of the bed, I doubt the top is the same temperature the thermistor indicates.
If you want traceable metrological accuracy in bed measurements, you will need to instrument/fixture the bed using embedded thermocouples or thermistors.  It will be a fun engineering project for you.
I set my bed temp to 60c; the actual print surface of the PEI sheet measures around 54c.  There are warm spots, there are cool spots.  But 10% of set temp is close enough for a bed that is fixtured the way it is.   If I were concerned, I'd raise my base bed temp in my slicer to 65 or even 67c and been happy.  I could even test 60, 80, and 100c and makes needed corrections in my slicer settings... but again, 10% is close enough. And I know the back side temp is whatever the probe is telling me.
ps: if you have to set the programmed temp to 85 to get 60, you have an assembly problem and should get it fixed.
And what emissivity is your IR thermometer set to? And what is the emissivity of the surface you are measuring?
Ce message a été modifié il y a 7 years 4 fois par --
Publié : 23/10/2019 12:25 am
glaceon
(@glaceon)
I'd agree that the IR thermometers could be inaccurate, and you can receive the wrong measurement. But nowadays there are some models that have pretty decent accuracy (at least +-1%, I'm not sure about 0,5%). If I were you I'd measure the temperature with at least 2 different thermometers and try different spots. Interesting to know which unit did you use. Many articles recommend Fluke models but not everyone is ready to spend their money on it because it is a bit pricey (for this type of product).
Not all those who wander are lost
Publié : 02/04/2020 2:57 pm
glaceon
(@glaceon)
Posted by: @john-vanderboom48
I've done some additional research and found out that ennoLogic brand also has the IR thermometers with +-1% accuracy. I thought this information would also be useful to someone. 😉
Publié : 03/04/2020 5:08 am
scimmiettarossa
(@scimmiettarossa)
I have the same issue.. recently I discovered that, printing at 60°C of bed temp, I was able to keep the hand on the bed (previously it was hurting!)
So I interposed a thermocouple between the bed and the sheet (obviously not printing, due to the increased thickness, and I made some tests:
  • heating at 60°C --> thermocouple reads 49
  • heating at 85°C --> thermocouple reads 70
apparently the thermistor is fixed in place.. could it be possible that it is shifting? kind of ageing?
Publié : 24/05/2020 7:12 pm
brannon.moore
(@brannon-moore)
Posted by: @vnirnn66
did you ever figure out what was happening here?  i have noticed similar issues on my plate / sheet.
Publié : 27/10/2020 3:10 pm
vintagepc
(@vintagepc)
Membre
There's an explicit bed temperature correction factor in the firmware that cases this discrepancy.
see https://github.com/prusa3d/Prusa-Firmware/issues/2642
Publié : 27/10/2020 3:25 pm
My cheap IR thermometer is convinced my body temperature is several degrees cooler than my medical thermometer, so I have to add correction there. The on-board firmware can compensate for "normal" bed conditions, but if I'm using a different print surface (textured, smooth, brand X, cold room), it can't know the actual print surface temp. I just assume it's going to be a bit low. I get good results with 68C for PLA.
Publié : 27/10/2020 6:20 pm
