Disable Thermal Anomaly Detection For Nozzle Change
Jason F.
(@jason-f)
Original Prusa i3 mk3 (upgraded to mk3s)
As the title says, it would be very nice to disable the thermal anomaly detection when you are about to perform a nozzle change. I usually heat the nozzle to around 290 to make sure it is tightened correctly. However, this new thermal anomaly detection makes the process a pain since it will scream at me with beeps before shutting off. So I have to tighten the new nozzle quickly (not a great thing to do) and clear the errors once the printer finally calms down.
Is there a way to temporarily disable this detection? If not, then I suggest that there should be an option to do so.
This topic was modified 3 years temu by Jason F.
Opublikowany : 15/12/2023 10:58 pm
RE: Disable Thermal Anomaly Detection For Nozzle Change
Starting with firmware 3.12, there's an option in  the LCD menu under Settings→HW Setup for Nozzle Change, which is not perfect but will temporarily disable the thermal overlord.
https://help.prusa3d.com/article/changing-or-replacing-the-nozzle-mk2-5s-mk3s-mk3s_2069
Opublikowany : 16/12/2023 12:05 pm
