Disable SD Card Slot
I was wondering if there is a way to disable the SD Card slot on the i3 MK3S printer? The idea behind this is to force users to go through the print server and not just walk up to a printer with an SD card and start printing. Ideally I'd prefer not to physically damage the SD Cards slots so I was wondering if anyone has been able to disable the card slot in firmware?
Publié : 21/05/2019 9:14 pm
RE: Disable SD Card Slot
Did you every find a solution to your problem? I am attempting to do the same thing at my university.
Publié : 16/02/2023 8:52 pm
You could print a half height dummy SD card to insert and block the slot whilst being removable by an authorised technician forewarned to carry a pair of tweezers.
Publié : 17/02/2023 2:32 am
