Difference in Thermal Drift between PLA and PETG
My hot end has a lot more drift when I'm printing hotter temperatures than it does when I'm printing at lower temps. I think it's the thermistor, but why would it behave differently at lower temps?
PLA
PETG
Thanks!
Best Answer by JoanTabb:
the PID settings are temperature dependent,
some folk find the ideal PID settings for different filaments, and add them to the custom gcode, start gcode, for the filaments,
https://3dprinterly.com/how-to-calibrate-your-hotend-heatbed-with-pid-tuning/
others decide which is their most used temperature, and run the prusa PID configuration for that temperature
https://all3dp.com/2/3d-printer-pid-tuning/
hope this helps, Joan
RE: Difference in Thermal Drift between PLA and PETG
Awesome! I didn't realize the PID calibration was temp dependent. Thank you!
