Did I break my filament sensor
I tried replacing the filament sensor cover with this, and now my filament sensor doesn't work anymore.
Here's a closeup shot of it.
Did I break my filament sensor? I think I did, but before I spend the money, I want to be sure.
Thanks
Rick
I hope that picture works!
Re: Did I break my filament sensor
Can't see a picture, just an icon:
403. That’s an error.
Your client does not have permission to get URL /e87gRNpynFTB_4xh22gg1aoqYfe2NoHvhJhW5Lz202W-9NFZKqF-hqMUVaDDa9QctoFbEQxL4MdDKrReJNuL=w1366-h637-rw from this server.
Attach the picture using the attach link.
I'm sorry about that. It showed up in preview, so I thought it was OK. I've attached it to the reply, I think.
Yes your filament sensor is broken. However I doubt the new cover broke it as the damage is due to heat and not mechanical stress. Before paying for a replacement I suggest contacting support via live chat as a burnt out filament sensor is a common fault due to a design flaw. Apparently Prusa are updating the design of the sensor at the moment.
Regards,
Martin
Martin Wolfe
give them the URl for this thead on the forum. and tell them there is a picture, here
I know I broke it. It was working fine, and then I installed the new cover. In order to get the PTE tube into the new head far enough, I had to screw it in and allow that to force it. That stress is what broke it. This is, to me, a clear case of abuse.
Thanks for helping confirm it's broken. Like I said, I thought it was, but wanted to be sure.
Rick
