Desert Island Parts Box
Coyoteran
(@coyoteran)
Ok so I don't exactly live on a desert island but Moose Jaw Canada is pretty damn close when it comes to getting spare parts. So besides your standard box of printed pieces, what would you, the more experienced printing community at large, deem as must have spare parts for your Mk3 so your printer isn't offline for two weeks while your new bits arrive from Prague.
Full disclosure. This is my first and only 3d printer and I bought the kit. I has been working great but a partially clogged nozzle that didn't respond the any of the common fixes left it idle for a couple of weeks. A blowtorch to the removed nozzle ultimately solved the issue but I don't know if my next break will be that easy to fix.
Thanks in advance
Trevor
Veröffentlicht : 18/05/2018 3:44 am
Re: Desert Island Parts Box
Hi Trevor
These lists can get quite long.
May i suggest. You try and find a like minded person in your locale
Who might be able to pront spare parts if you have a problem.
Then .
No particular order...
Heater 24v for mk3
Bed and extruder thermistors
Left hand noctua fan
Front part fan
Heat shrink tubing.
Flexible wire. For heatbed pinda and motor wire repairs
Soldering iron and solder
Cable ties
Gt2 belt
Nozzles
Ptfe tube... pencil sharpener and taper cutter /reamer
Spare grub screws motor gears. Bondtech and hot end thermistor
Spare 3mm cap head screws
Pei sheet limmonene
Ipa and acetone
Windex
Disposeable paper towels
Sponge with Green kitchen scrubber
Spare SD card
Flush cut wirecutters
Hex keys ball end...
Thars a starting list
R3gards Joan
Veröffentlicht : 18/05/2018 11:15 am
Coyoteran
(@coyoteran)
Awesome. Thanks for the starter list.
Of course I don't bother to ask these questions until after I put in an order to the Prusa shop. Hopefully nothing goes south until I am ready to get more consumables.
Hopefully a few more folks from the local area catch on to this 3d printing thing. I have been preaching the gospel of the Mk3 ever since I got it, trying to do my part. 🙂
T
Veröffentlicht : 18/05/2018 11:08 pm
