Default Settings Horrible Print
Anthony
(@anthony-7)
Hey guys I haven't used my printer in months because of this. My prints with support material are coming out very bad. I started printing this plain floating rectangle to narrow it down. As you can see in the pictures, the print starts perfect and the support material going in the x axis is fine then the layer it starts printing perpendicular in the y axis is awful. That mess is a single layer so imagine this for an entire print and whatever object that sits on top of this birds nest of support material. The printer is good, nozzle is good, bed is good and calibrated. This has to be a software setting type problem but I can't figure it out. I don't understand how default settings can do this and every custom setting I put does nothing. Thoughts? Please help.
Opublikowany : 26/11/2023 10:45 pm
