Cut Problem
I am having fits with Slic3r PE. Most of the time when I try to cut a few mm off the bottom of a down loaded project that has a bad bottom, the slicing program keeps saying "not responding" and wants to close program. It has worked on a few projects but not about 95% of them. Any suggestions will be appreciated.
Thanks, 😕 Just A Newbie 😀
Respondido : 12/05/2019 10:25 pm
RE: Cut Problem
Works for me 99% of the time. Usual suspects when it fails are multiple shells, part isn't manifold, a zillion vectors, or a part that would end up as multiple shells is cut. I have a fast cpu and yet some cuts take quite a while ... if a cut goes non-responsive, I'll go have a cup of coffee and it's usually done when I come back.
What's wrong with the bottom you are trying to trim off?
Esta publicación ha sido modificada el hace 7 years por --
Respondido : 13/05/2019 4:01 am
