Custom Supports
Littleted
(@littleted)
Custom Supports
Guys just a quick one, am i right in thinking for any support enforcers to show up i need to also have support enforcer for the first ??? defined.
What im seeing is if i add custom support the normal way by only having auto generate supports they never appear ?
thanks
Respondido : 29/10/2020 9:24 am
RE: Custom Supports
I'm not following ... but first you place an enforcer(s). Then you enable them.
Alternatively, you can enable enforcers, then place them.
Esta publicación ha sido modificada el hace 6 years 2 veces por --
Respondido : 29/10/2020 8:53 pm
TheMadJedi
(@themadjedi)
RE: Custom Supports
I added some custom supports to a model i was printing to support the trigger, it was added but not as large as I wanted it didn't cover the whole trigger. I enlarged the custom support area and this time the supports where generated the way I wanted
Respondido : 30/10/2020 6:20 am
RE: Custom Supports
As a future note: the supports only need to touch the surface that is to be supported.  You can place a smaller box around the trigger and the supports will still generate. 2.3.0 Alpha has paint on support enforcers. Well worth the price of admission.
Respondido : 30/10/2020 6:28 am
