Cube added on object to be sliced
jj57
 jj57
(@jj57)
Hello!
Since upgrading to Slicer 2.5 every time I try to slice an .stl a cube is added on the plate , how can I remove it ?
Thanks a lot !!!
Postato : 26/09/2022 3:14 pm
Artur5
(@artur5)
RE: Cube added on object to be sliced
That cube looks like the purge generated when you use the multimaterial ( MMU2) accessory to print with several filaments. In all likelihood, when you updated to PS 2.5  you selected by chance or mistake  the MK3S + MMU2 as default printer.
Just go to “réglages de l’imprimante” and select the correct model of printer  ( without MMU2 ).
Postato : 26/09/2022 4:16 pm
jj57
 jj57
(@jj57)
Hello Artur5
  You're absolutely right , thanks a lot ... I'm feeling a little bit stupid 🙁
Postato : 26/09/2022 4:22 pm
