Crash with screen full of unreadable text
Mike in the D
(@mike-in-the-d)
I have a model that causes a crash.  I was able to print this a few times.  How do I upload the model?   I sent an email to info@prusa3d.com as well.
Running Firmware 3.8.1-2869
Prusa Slicr Version 2.20+win64
Napsal : 01/04/2020 3:15 pm
RE: Crash with screen full of unreadable text
Posted by: @mludlum
Have you changed anything on the printer recently, e.g. flashed the firmware? Electrostatics can also cause this.
Napsal : 01/04/2020 3:33 pm
Mike in the D
(@mike-in-the-d)
@karl-herbert
No, I updated the firmware several weeks prior.  At first I thought it was the model triggering the crash since it was happening in the same spot.  So, I rotated the model slightly and was able to do a few prints without trouble.
But last night It happened again.  The only thing I did differently on this last print was put some glue on the plate because the PETG was sticking too hard.
 Someone else posted a similar screen and mentioned Octoprint.  I updated Octoprint and I'll try again.
Napsal : 01/04/2020 3:58 pm
Christian
(@christian-2)
Same problem tonight 🙁
- Same FW and Slicer versions
- octoprint 1.40
I'll also try it direct from SD-Card.
Napsal : 03/04/2020 8:05 am
Christian
(@christian-2)
I found the problem.
The temp-sensor cable behind the heatbed seems to be broken. When I push it, min-Temperature goes to 0 C.
I used it for a month now 🙁
Napsal : 03/04/2020 8:37 am
@cyberchriss
Thanks for the feedback. Interesting that a broken thermistor cable is causing this problem. I would exchange it for a heat-resistant and flexible silicone cable (cut off in the moving area, insert the silicone cable, solder and isolate with a shrink tube). I solved it this way, since 2 years no broken cable anymore.
Napsal : 03/04/2020 8:55 am
Christian
(@christian-2)
@karl-herbert
I'll try to reach the prusa support via chat atm. I used the printer for 1 month now and this shouldn't happen after such a short time 🙂
Napsal : 03/04/2020 9:12 am
Christian
(@christian-2)
Prusa support told me that it's not a waranty case because the cable was not build in correctly. So I was forced to order a new cable-kit 🙁
From my point of view, the cable was installed correctly and the cable damage was a consequence of a design fail of the plastic case.
Any other people here that had the same problem? How did you solve this?
s
Napsal : 03/04/2020 12:49 pm
The sleeve is supposed to extend into the plastic.  The other thing I did was to route the thermistor wires into the slight dip between the black and red heat bed wires.   That way the thicker wires provide protection to the thinner wires from one side.   I bought the MK3 a couple of years back and its not had any problems with the wires in all that time.
Napsal : 03/04/2020 1:23 pm
Christian
(@christian-2)
@neophyl
Of course I put the sleeve into the plastic cover. I'll try to put the cable beetween the two thicker wires next time. Maybe this helps 🙂
Napsal : 03/04/2020 1:56 pm
@cyberchriss
Since this is a particularly sensitive area, I protected the cables with a rubber sleeve and also printed a new cover with a larger opening. You have to be very careful there, also in the area of the Einsy housing. If you have a soldering station, I would, as already mentioned, replace this area with heatresistant and flexible silicone cables (Thermistor and 24V connections). A new thermistor you can buy in some stores. The MK3 is good but you can always do it better...
Napsal : 03/04/2020 2:06 pm
