Configuration wizard won't add .25 nozzle configuration for MK3SMMU2S
GBelfor
(@gbelfor)
I went into the Configuration Wizard on PrusaSlicer 2.1.0 to add .25 and .60 nozzle as well as the standard .40 nozzle.  All three selected.
I get all three nozzle sizes for the "Single" version, but only the standard and the .60 nozzle size for the MMU versions.  Here's the configuration snapshot:
10/3/2019 5:46:51 PM: User (WhatGives?)
slic3r version: 2.1.0+win64
print: 0.15mm QUALITY MK3
filaments: Prusament PLA MMU2
printer: Original Prusa i3 MK3S MMU2S
vendor: PrusaResearch, version: 1.0.3, min slic3r version: 2.1.0-alpha0
model: MK3SMMU2S, variants: 0.25, 0.4, 0.6
...I see the .25 variant here, but it's not available in the drop down for  printers.
Can I fix this manually in the INI files?
Publié : 03/10/2019 11:49 pm
jebtrix
(@jebtrix)
RE: Configuration wizard won't add .25 nozzle configuration for MK3SMMU2S
I'm not sure if its omission is intentional (dont have your printer to test) but if you want to try it anyway the easiest way is to edit \vendor\PrusaResearch.ini in your profile folder and add this to the end:
NOTE: The slicer checks for default Prusa profile updates on start-up by default. This change would have to be redone if you apply the update.
[printer:Original Prusa i3 MK3S MMU2S 0.25 nozzle]
inherits = Original Prusa i3 MK3S MMU2S
nozzle_diameter = 0.25,0.25,0.25,0.25,0.25
max_layer_height = 0.15
min_layer_height = 0.05
printer_variant = 0.25
default_print_profile = 0.10mm DETAIL 0.25 nozzle MK
Publié : 06/10/2019 2:59 am
GBelfor
(@gbelfor)
@jebtrix
Thanks for the guidance...I gave that a try, but when I start PrusaSlicer after adding those lines to the end, I get a big error box saying "PrusaSlicer has encountered an error", followed by a huge list:
Vendor configuration file PrusaResearch contains the following presets with names used by other vendors: 0.05mm ULTRADETAIL, 0.05mm ULTRADETAIL 0.25 nozzle, 0.05mm ULTRADETAIL 0.25 nozzle MK3, 0.05mm ULTRADETAIL MK3, 0.07mm ULTRADETAIL 0.25 nozzle MK3, 0.07mm ULTRADETAIL MK3, 0.10mm DETAIL, 0.10mm DETAIL 0.25 nozzle, 0.10mm DETAIL 0.25 nozzle MK3, 0.10mm DETAIL MK3, 0.15mm 100mms Linear Advance, 0.15mm 100mms Linear Advance MK2.5, 0.15mm DETAIL 0.6 nozzle MK3, 0.15mm OPTIMAL, 0.15mm OPTIMAL 0.25 nozzle, 0.15mm OPTIMAL 0.6 nozzle, 0.15mm OPTIMAL MK2.5, 0.15mm OPTIMAL SOLUBLE FULL, 0.15mm OPTIMAL SOLUBLE FULL MK2.5, 0.15mm OPTIMAL SOLUBLE INTERFACE, 0.15mm OPTIMAL SOLUBLE INTERFACE MK2.5, 0.15mm QUALITY 0.25 nozzle MK3, 0.15mm QUALITY MK3, 0.15mm SOLUBLE FULL MK3, 0.15mm SOLUBLE INTERFACE MK3, 0.15mm SPEED MK3, 0.20mm 100mms Linear Advance, 0.20mm 100mms Linear Advance MK2.5, 0.20mm DETAIL 0.6 nozzle MK3, 0.20mm NORMAL, 0.20mm NORMAL 0.6 nozzle, 0.20mm NORMAL MK2.5, 0.20mm NORMAL SOLUBLE FULL, 0.20mm NORMAL SOLUBLE FULL MK2.5, 0.20mm NORMAL SOLUBLE INTERFACE, 0.20mm NORMAL SOLUBLE INTERFACE MK2.5, 0.20mm QUALITY MK3, 0.20mm SOLUBLE FULL MK3, 0.20mm SOLUBLE INTERFACE MK3, 0.20mm SPEED MK3, 0.30mm DRAFT MK3, 0.30mm QUALITY 0.6 nozzle MK3, 0.30mm SOLUBLE FULL 0.6 nozzle MK3, 0.30mm SOLUBLE INTERFACE 0.6 nozzle MK3, 0.35mm FAST, 0.35mm FAST 0.6 nozzle, 0.35mm FAST MK2.5, 0.35mm FAST sol full 0.6 nozzle, 0.35mm FAST sol int 0.6 nozzle, 0.35mm SOLUBLE FULL 0.6 nozzle MK2.5, 0.35mm SOLUBLE INTERFACE 0.6 nozzle MK2.5, 0.35mm SPEED 0.6 nozzle MK3, 0.40mm DRAFT 0.6 nozzle MK3, 0.025 UltraDetail, 0.035 Detail, 0.05 Normal, 0.1 Fast, ColorFabb HT, ColorFabb HT MMU1, ColorFabb PLA-PHA, ColorFabb XT, ColorFabb XT MMU1, ColorFabb XT-CF20, ColorFabb XT-CF20 MMU1, ColorFabb bronzeFill, ColorFabb copperFill, ColorFabb corkFill, ColorFabb nGen, ColorFabb nGen MMU1, ColorFabb nGen flex, ColorFabb steelFill, ColorFabb woodFill, E3D Edge, E3D Edge MMU1, E3D PC-ABS, Fillamentum ABS, Fillamentum ASA, Fillamentum CPE, Fillamentum CPE MMU1, Fillamentum PLA, Fillamentum Timberfill, Generic ABS, Generic ABS MMU2, Generic FLEX, Generic FLEX MMU1, Generic PET, Generic PET MMU1, Generic PET MMU2, Generic PET MMU2 0.6 nozzle, Generic PLA, Generic PLA MMU2, Polymaker PC-Max, PrimaSelect PVA+, PrimaSelect PVA+ MMU2, Prusa ABS, Prusa ABS MMU2, Prusa HIPS, Prusa PET, Prusa PET 0.6 nozzle, Prusa PET MMU1, Prusa PET MMU2, Prusa PET MMU2 0.6 nozzle, Prusa PLA, Prusa PLA MMU2, Prusament ASA, Prusament ASA MMU2, Prusament PETG, Prusament PETG 0.6 nozzle, Prusament PETG MMU1, Prusament PETG MMU2, Prusament PETG MMU2 0.6 nozzle, Prusament PLA, Prusament PLA MMU2, SemiFlex or Flexfill 98A, SemiFlex or Flexfill 98A MMU1, Taulman Bridge, Taulman T-Glase, Taulman T-Glase MMU1, Verbatim BVOH, Verbatim BVOH MMU2, Verbatim PLA, Verbatim PP, 3DM-ABS 0.025, 3DM-ABS 0.05, 3DM-BLACK 0.05, 3DM-DENT 0.05, 3DM-HR Green 0.05, 3DM-HR Red Wine 0.05, 3DM-HTR140 (high temperature) 0.05, 3DM-Vulcan Gold 0.025, 3DM-Vulcan Gold 0.05, 3DM-XPRO White 0.05, Ameralabs AMD 3 LED 0.05, Asiga Denta Model 0.05, BlueCast 23LS 0.05, BlueCast EcoGray 0.025, BlueCast EcoGray 0.05, BlueCast EcoGray 0.1, BlueCast Kera Master Dental 0.025, BlueCast Kera Master Dental 0.05, BlueCast Kera Master Dental 0.1, BlueCast LCD-DLP Original 0.05, BlueCast Phrozen Wax 0.025, BlueCast Phrozen Wax 0.05, BlueCast S+ 0.05, BlueCast X10 0.025, BlueCast X10 0.05, BlueCast X5 0.05, Esun Bio-Photopolymer Resin White 0.025, Esun Bio-Photopolymer Resin White 0.05, Esun Standard Resin Black 0.025, Esun Standard Resin Black 0.05, FTD Ash Grey 0.05, Harz Labs Model Resin Cherry 0.05, Monocure 3D Black Rapid Resin 0.05, Monocure 3D Blue Rapid Resin 0.05, Monocure 3D Clear Rapid Resin 0.05, Monocure 3D Grey Rapid Resin 0.05, Monocure 3D White Rapid Resin 0.05, Photocentric Ash Grey 0.025, Photocentric Ash Grey 0.05, Photocentric Hard Grey 0.05, Prusa Azure Blue Tough 0.025, Prusa Azure Blue Tough 0.05, Prusa Azure Blue Tough 0.1, Prusa Beige Tough 0.025, Prusa Beige Tough 0.05, Prusa Beige Tough 0.1, Prusa Black Tough 0.05, Prusa Black Tough 0.1, Prusa Clear Flexible 0.05, Prusa Green Casting 0.025, Prusa Green Casting 0.05, Prusa Green Casting 0.1, Prusa Grey Tough 0.025, Prusa Grey Tough 0.05, Prusa Maroon Tough 0.025, Prusa Maroon Tough 0.05, Prusa Maroon Tough 0.1, Prusa Orange Tough 0.025, Prusa Orange Tough 0.035, Prusa Orange Tough 0.05, Prusa Orange Tough 0.1, Prusa Pink Tough 0.025, Prusa Pink Tough 0.05, Prusa Pink Tough 0.1, Prusa Transparent Red Tough 0.05, Prusa Transparent Tough 0.025, Prusa Transparent Tough 0.05, Prusa Transparent Tough 0.1, Prusa White Tough 0.025, Prusa White Tough 0.05, Prusa White Tough 0.1, Resinworks 3D Violet 0.025, Resinworks 3D Violet 0.05, Original Prusa SL1, Original Prusa i3 MK2.5, Original Prusa i3 MK2.5 0.25 nozzle, Original Prusa i3 MK2.5 0.6 nozzle, Original Prusa i3 MK2.5 MMU2, Original Prusa i3 MK2.5 MMU2 0.6 nozzle, Original Prusa i3 MK2.5 MMU2 Single, Original Prusa i3 MK2.5 MMU2 Single 0.25 nozzle, Original Prusa i3 MK2.5 MMU2 Single 0.6 nozzle, Original Prusa i3 MK2.5S, Original Prusa i3 MK2.5S 0.25 nozzle, Original Prusa i3 MK2.5S 0.6 nozzle, Original Prusa i3 MK2.5S MMU2S, Original Prusa i3 MK2.5S MMU2S 0.6 nozzle, Original Prusa i3 MK2.5S MMU2S Single, Original Prusa i3 MK2.5S MMU2S Single 0.25 nozzle, Original Prusa i3 MK2.5S MMU2S Single 0.6 nozzle, Original Prusa i3 MK2S, Original Prusa i3 MK2S 0.25 nozzle, Original Prusa i3 MK2S 0.6 nozzle, Original Prusa i3 MK2S MMU1, Original Prusa i3 MK2S MMU1 0.6 nozzle, Original Prusa i3 MK2S MMU1 Single, Original Prusa i3 MK2S MMU1 Single 0.6 nozzle, Original Prusa i3 MK3, Original Prusa i3 MK3 0.25 nozzle, Original Prusa i3 MK3 0.6 nozzle, Original Prusa i3 MK3 MMU2, Original Prusa i3 MK3 MMU2 0.6 nozzle, Original Prusa i3 MK3 MMU2 Single, Original Prusa i3 MK3 MMU2 Single 0.25 nozzle, Original Prusa i3 MK3 MMU2 Single 0.6 nozzle, Original Prusa i3 MK3S, Original Prusa i3 MK3S 0.25 nozzle, Original Prusa i3 MK3S 0.6 nozzle, Original Prusa i3 MK3S MMU2S, Original Prusa i3 MK3S MMU2S 0.6 nozzle, Original Prusa i3 MK3S MMU2S Single, Original Prusa i3 MK3S MMU2S Single 0.25 nozzle, Original Prusa i3 MK3S MMU2S Single 0.6 nozzle
Publié : 07/10/2019 11:47 pm
