config.h file lang mode
chrischin
(@chrischin)
When the compile instructions say "In file "Firmware/config.h" set LANG_MODE to 0" does that just mean remove the "#" form the LANG_MODE line? Like this:
//define LANG_MODE 0 // primary language only
Or like this?
//define LANG_MODE = 0 // primary language only
Opublikowany : 31/01/2019 8:31 pm
stahlfabrik
(@stahlfabrik)
Re: config.h file lang mode
Yes this
Opublikowany : 01/02/2019 3:15 pm
chrischin
(@chrischin)
Which example lol?
Opublikowany : 01/02/2019 4:06 pm
chrischin
(@chrischin)
Yes this
There are two "this". Which one?
Opublikowany : 01/02/2019 4:07 pm
stahlfabrik
(@stahlfabrik)
Ah tried to be funny, because I did not see the "=" in your post
The line is
#define LANG_MODE 1 // sec. language support
and you change that to
#define LANG_MODE 0 // sec. language support
You do NOT remove the "#"
Opublikowany : 04/02/2019 11:11 am
chrischin
(@chrischin)
Thanks so much! Worked like a charm.
Opublikowany : 09/02/2019 1:40 am
