Clogged somewhere, usual steps don't help
SimonD
(@simond)
Printer worked well for >1 year basically without any trouble
Yesterday i had a print that just stopped printing halfway through (stepper motors clicking, I stopped the print to prevent more damage) and I cannot get the print the printer to print anything since then.
I can push a bundled acupuncture needle up from the bottom without any resistance. I can push in a 1mm brass wire all the way to the bottom of the hotend with no resistance. My first cold pull worked somewhat, but had a really weird profile at the end of the filament (different from what I've seen before). Yet when I try to do another cold pull I cannot manually push filament through to have it come out the hotend. Stepper motors are still working because they feed the filament successfully for part of the load and unload actions.
Opublikowany : 03/03/2022 6:02 am
