Can't send individual G Code Commands
When I try to use pronterface to send a g code command it fails. I originally was on 3.5.1 and upgraded to 3.7.1 firmware with the same issue. I've tried 2 different computers. I've verified the printer is properly connected to the computer (device manager is good). I've verified I'm using the correct COM port and the right baud rate. I can use the same COM port to upgrade the firmware without issue.
This worked before upgrading to 3.5.1.
Any advice would be really helpful. Thanks!
Publié : 14/06/2019 9:57 pm
