Can't print or calibrate since wrong firmware installed
jacob.t6
(@jacob-t6)
I ordered a mk3, I was sent a mk3s no complaints but I wasn't told this so I updated with mk3 firmware and everything went to hell.  I reinstalled mk3s firmware but can't calibrate my printer or make the simplest prints.  It has me pretty upset so any help on fixing this would be greatly appreciated.
Opublikowany : 25/06/2019 8:37 pm
Dave Avery
(@dave-avery)
RE: Can't print or calibrate since wrong firmware installed
do a factory reset
Opublikowany : 25/06/2019 9:23 pm
Bunny Science
(@bunny-science)
WITH deletion of all data
Opublikowany : 25/06/2019 11:33 pm
Factory Reset with Data Clear (it's a menu selection when doing the reset).  If you miss the Data Clear, you have not done a reset of the EEPROM variables that are probably corrupted.
Opublikowany : 26/06/2019 9:42 am
jacob.t6
(@jacob-t6)
thank you it worked so far calibrated and printed the batarang test since it was quick.  Once again thanks for the advice
Opublikowany : 26/06/2019 11:51 pm
