Can't load filament / disable filament sensor
Tarrant1701
(@tarrant1701)
Ever since I first bought the MK3, the filament sensor wasn't working well and so I had disabled it. Recently, updated firmware to 3.13.2 but afterwards filament sensor was re-enabled. As a result, I can no longer manually load filament as the only option is autoload filament. I try to disable the filament sensor by going to setting -> filament sensor -> on/off, but no matter what I click, it will always stay "On."
Any thoughts on how to allow manual loading of filament?
Posted : 28/12/2023 7:52 pm
Tarrant1701
(@tarrant1701)
RE: Can't load filament / disable filament sensor
PS. Here's the reason why my filament sensor never worked... take a look at that component in the lower right corner!
Posted : 28/12/2023 9:34 pm
