[Solved] Can't load any filament
IzK
 IzK
(@izk)
I was printing a 2 color piece and on a color change, the printer throw the usual mmu load failed, but this time the issue was on the extruder.
I can't load any filament. From top I can insert 10cm of filament but don't get melted. I can insert completely the acupuncture needle from below without issue. And as prusa recommended, I checked the PTFE tube and looks perfect (I've no replacement left).
What can I do? Any suggestions?
Napsal : 03/06/2021 10:50 pm
IzK
 IzK
(@izk)
RE: Can't load any filament
The needle don't reach the filament from above. There is a small gap of about 2mm.
Napsal : 04/06/2021 1:17 pm
IzK
 IzK
(@izk)
Finally I've found the clog: A multicolor piece of filament stuck on the heatsink.
Napsal : 05/06/2021 11:08 am
