Can't get anything to stick to textured print bed
Page 1 / 2
acetech09
(@acetech09)
Hi everyone. I ordered a textured bed a few weeks ago, and can't get anything to stick.
All the following pictures and descriptions have been printed with the following setup:
  • Stock MK3S (that prints perfectly on a PEI sheet)
  • 'Official' Ikea LACK enclosure.
  • Prusament filament (Both PLA and PETG), fresh out of the bag, with PrusaSlicer default settings.
  • Bed wiped with 100% IPA before each print.
After getting the textured sheet, the first thing I tried printing was parts for another lack enclosure. I ran the first layer cal, went for what looked right, but here was the result (Prusament PETG, default settings):
The parts didn't really stick at all, and warped heavily. Even when hot, I could just touch any of the parts with my finger and they were sliding around.
After scrubbing the plate with dish soap and water, the bed adhesion increased enough for me to finish those prints. But it was far from perfect.
Next up, I tried printing some large flat PLA parts. And again, almost no bed adhesion and some warping even on PLA:
Is there something I'm missing? I've adjusted my z-height a handful of times, and have had the same results, pic of the calibration squares that seemed to work the best (0.6mm nozzle):
Any advice would be appreciated. I heard a lot of hype about these plates but i can't get any prints off on them successfully.
Posted : 02/01/2020 12:02 am
rmm200
(@rmm200)
RE: Can't get anything to stick to textured print bed
Large flat objects will warp. Seems silly on a flat part - but add a brim. It helps.
And scrub your plate with Dawn again. No IPA this time, and never touch the print surface.
Posted : 02/01/2020 1:23 am
kirby
(@kirby)
PETG warping sometimes points to a low bed temp. Agree with the suggestion for brim too.
Posted : 02/01/2020 2:43 am
bgoner
(@bgoner)
I had the same problem at the beginning with the textured bed.
After increasing bed to 65C + cleaning the bed with isopropil alcohol everything is fine.
But I haven't printed so big objects.
Do you have octoprint to checkout the level of warping of the bed? BTW there is a way to dump this info when plugged with the USB - 2 commands but you need to search for them. If severly warped you could use the nylon nut bed levelling
This post was modified 5 years ago by bgoner
Posted : 03/01/2020 12:30 pm
acetech09
(@acetech09)
Thanks for the responses so far.
For the small PETG parts I'll try re-Dawning it, but without IPA this time. And, if that doesn't work, upping the temp.
Re: the flat PLA parts, those parts print just fine on a PEI bed, there is plenty of adhesion to naturally resist the warp. Same exact g-code as before:
I understand methods for reducing warp generally speaking. But my question was specifically about whether reduced bed adhesion is normal on the Textured bed, and whether there's ways of mitigating it.
Posted : 04/01/2020 8:27 pm
rmm200
(@rmm200)
Reduced bed adhesion is normal on the textured bed. It gets better with use.
Stick a brim on your parts...
Posted : 05/01/2020 4:21 am
bgoner
(@bgoner)
Definitely PEI has better adhesion
I feel the same way, but didn't mention it as I though I was making it up 🙂
Posted : 05/01/2020 5:54 pm
Edgehog
(@edgehog)
I Bought 2 a little while before Christmas and kind of getting to the point of giving up on them. Up till now I have been printing on a variety of genuine and third party smooth and cheapo PEI textured imports. Thought I'd buy some genuine now they were readily available and wishing I hadn't.
I have no trouble with any other surface, and I have a few, but these sheets are better than Teflon for not sticking. I've tried a whole range of materials and layer heights all to no effect.
Posted : 09/01/2020 4:34 pm
rmm200
(@rmm200)
If you are at the point of giving up on them - try scouring one side only with a Scotchbrite pad.
Repeat the Dawn scrub.
Use a bed temp of 80.
Get your Z calibration right. Maybe post a calibration square.
Let us know how that goes.
Posted : 09/01/2020 4:41 pm
Edgehog
(@edgehog)
@robert-rmm200
I'll have another play with them tomorrow. I have 5 machines but the sheets only can be used on three of them realistically, one genuine and two home brews both based on Mk3's one with a Bear frame and extruder.  All give me issues. I have to calibrate the Bear frame using the custom firmware then switch to Prusa for the layer cal. All give me good even results but they just don't stick. Tried 4 different brands of PLA including Prusament, 3 brands of PETG and 3types of PLA+.
I have a day off tomorrow so I'll spend some time but really shouldn't be this hard. My Aliexpress cheapos work fine out the bag.
Cheers
Posted : 09/01/2020 6:52 pm
Edgehog
(@edgehog)
One thing I forgot to mention is that even the silk screening wont adhere to the bed. A couple of PLA prints on this sheet and the PLA lifts the screen.
Posted : 10/01/2020 9:18 am
Edgehog
(@edgehog)
Checked bed to rail height at 9 points with caliper and all within +/- 0.02mm apart from front right corner which for some reason is low by 0.1mm ? Probably leaned on it at some point.
Cleaned sheet with Fairy, which is same as Dawn with low abrasive Scotch Brite 7447 pad. Interesting how the PEI doesn't wet almost like it's water repellent. Re-calibrated and no joy. Anything more than below and I am over squashing (it's to low below anyway) and I end up dragging .
The test below (PLA @ 230°C & 65°C) fell off whole I was moving it to take pictures. Tried PLA @ 230°C & 85°C and corners of outer squares lifted. The lack of wetting bothers me, not being a chemist I don't know how PEI should behave when washed but I will get a stronger degreaser later today and try cleaning with that. Will try and get someone on the chat line as well as it's bugging me now.
Posted : 10/01/2020 1:13 pm
vintagepc
(@vintagepc)
Clean PEI should have water bead off it just like a freshly waxed car or non-stick baking sheet. Otherwise, it has contaminants on it.
Posted : 10/01/2020 4:57 pm
Edgehog
(@edgehog)
Think I've got to the bottom of the problem. A friend sent me a spare sheet and it arrived this morning. Test print sticks like the proverbial snot to a chickens lip. What is quite obvious is that they are not the same. Comparing his on the left with mine on the right. Both with similar very light usage history. Going to email Prusa about replacing mine. Could go a long way to explaining why there is so much disparity between users on results with these sheets.
Posted : 11/01/2020 12:05 pm
bobstro liked
Good luck with support. I have one of the bad ones and was told by support that "it's a consumable" even if defective out of the packaging. There is definitely some variability in the quality of these things.
Posted : 11/01/2020 2:30 pm
featherz
(@featherz)
I haven't had too many problems with mine although I usually use it with PETG to avoid having to clean the you know what out of it for PLA.. But I just got a textured sheet for my CR-10S and OMG everything sticks to that like a dream.. I wonder what the difference is?
Posted : 11/01/2020 3:55 pm
overflow
(@overflow)
@kevin-a11
You confirm my suspect , not all powder pei are the same . My sheet have the same colours of yours and don't stick , 50 euros wasted and Prusa don't admit this fact .
Posted : 12/05/2020 9:43 am
@kevin-a11
What are the lot numbers of the bad ones?
Posted : 12/05/2020 10:08 am
Edgehog
(@edgehog)
@charles-h13
Hi
Not sure there are lot numbers, seems to be luck of the draw. Managed to get a replacement from  Prusa but despite asking for a dark one they sent me a a lighter one and nowhere as good as the dark one. Recently acquired a 'second hand' dark one and adhesion is good. I've given up on the lighter coloured ones and now just use Dimafix spray on them which seems to work. That said even the Dimafix doesn't last as long on the suspect sheets as it does on every other print surface I have including cheap knock offs.
Have to say it has been a bit of a disappointment that it isn't being recognised as an issue.
Posted : 12/05/2020 5:00 pm
Turbotrix
(@turbotrix)
Hi I have the same issue with mine which arrived about month-and-a-half ago I've played with first layer calibration multiple number of times and when it comes to Prints longer than 3 hours and taller in this case I was printing x-axis parts for prusa they all end up warped at the end of the print but adhesion  seems to be okay.. still don't get it why? Everything seems normal on Pei sheet
This post was modified 4 years ago by Turbotrix
Posted : 01/09/2020 10:34 pm
Page 1 / 2
