Can't find Calibration Point
Page 2 / 3
Hello
(@hello)
have you tried disconecting the data and power cable from the mmu just incase thats interfiring also the cables are pluged in the right spots right because it kinda acts like the z motors are doing what the y axis should
Publié : 31/12/2022 11:27 pm
Hello
(@hello)
RE: Can't find Calibration Point
the y axis should move back and forward a little bit as the x goes left and right to draw a circle kind of
Publié : 31/12/2022 11:31 pm
Jonathan
(@jonathan-10)
Untitled (3)
Here is a video with the sheet. I also tried raising the metal sheet to almost touching the pinda probe and still does not detect it.
Publié : 31/12/2022 11:39 pm
Hello
(@hello)
strange
Publié : 31/12/2022 11:41 pm
Hello
(@hello)
it saying that the nozzle has hit the bed but it dident
Publié : 31/12/2022 11:42 pm
Hello
(@hello)
if you put a metal object on the pind in the position it dosent rechonize does it change the reading
Publié : 31/12/2022 11:44 pm
Hello
(@hello)
so put metal on the probe where the error came up and see if the light changes
Hello
(@hello)
there is one more thing you can try that might work do a factory reset when it says do you want me to take you through the clabration process click no then do the first layer calabration
Publié : 31/12/2022 11:47 pm
Jonathan
(@jonathan-10)
Untitled (5)
Here is a shot of the pinda probe. It shuts off on its way to the 3rd (corner) point. I put that piece of metal there to raise it up as a test but it does the same thing with and without. I tried the factor reset and then select no, same thing.
Publié : 01/01/2023 12:02 am
Hello
(@hello)
thats norowed it down to the pinda or the board
open up the electronics box make sure its pluged in corectly and take photo of the board with wires conected please
Publié : 01/01/2023 12:05 am
Hello
(@hello)
also this is going to seem strange disconect the x motor and run it again if the extruder stays in same place pinda stays on then shuts off then that really narrows it down
Publié : 01/01/2023 12:12 am
Hello
(@hello)
How long ago did you install the mmu
Publié : 01/01/2023 12:39 am
Jonathan
(@jonathan-10)
I unplugged the X motor and ran it again and it completed. Does that point to the board?
Publié : 01/01/2023 1:57 am
Jonathan
(@jonathan-10)
Also, I have had the mmu for 4 years.
Publié : 01/01/2023 1:58 am
Hello
(@hello)
so even with motor off the pinda still stops working
Publié : 01/01/2023 2:06 am
Hello
(@hello)
What i need you to do please is unplug evry thing on the board take board out of case
Hello
(@hello)
leave the power conectors conected not the bed only the ones to power board then plug in pinda and take close up photo
Publié : 01/01/2023 2:07 am
Hello
(@hello)
close up photo of the board please
Publié : 01/01/2023 2:16 am
Hello
(@hello)
so just so i got you right you unpluged the x motor and now it hasent come up with the error correct
Publié : 01/01/2023 2:48 am
Jonathan
(@jonathan-10)
The Z calibration completed on the side away from the bad side when the X axis was unplugged. When the printer was moved to the side where it had previously failed, it failed again immediately. This led the me to suspect the Pinda probe, which was found to have a broken wire when the cluster of cables was moved (See video Untitled (6)). A new Pinda will be ordered to fix the issue. Thank you so much @Hello for all your help and the suggestion to unplug the X motor, which led to the solution. Thank you.
Publié : 01/01/2023 2:49 am
Page 2 / 3
