Can't Complete First Layer Calibration Correctly - X-Axis Issues?
Jason
(@jason-9)
Hello,
I recently had an issue whereby the grub screw on the x-axis stepper motor came loose mid-print, which was causing the shaft to effectively spin in place without moving the belt the extruder is attached to.  After tightening the screw, I thought all was well and to be safe, I went through the calibration wizard (which completed without issues) and am now trying to go back through the first layer calibration.  Unfortunately, I'm having a problem whereby the "right" side of the print isn't printing properly.  I've attached some images to better explain what I'm talking about.  Hoping someone has some additional insight as to how I might go about addressing the issue.
Thanks!
Best Answer by Jason:
I resolved this by tightening my x-axis belt a little.
Opublikowany : 07/04/2020 12:44 am
Jason
(@jason-9)
RE: Can't Complete First Layer Calibration Correctly - X-Axis Issues?
Opublikowany : 26/04/2020 11:53 pm
